Re: Super M upper bolster seal
Posted by 47 Bill on September 13, 2012 at 09:07:28 from (173.166.167.77):
In Reply to: Re: Super M upper bolster seal posted by FBH44 on September 13, 2012 at 03:57:14:
Thanks for all the info. Especially about ordering extra seals and making your own puller.local Case/IH is now Kubota.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
