Re: Super M upper bolster seal
Posted by David G on September 13, 2012 at 18:13:00 from (205.215.206.18):
In Reply to: Super M upper bolster seal posted by 47 Bill on September 13, 2012 at 01:19:18:
Make sure and check the bushing clearances while the seal is out. I am sure it is worn and will need replacing.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
