Re: Farmall 100 fast hitch
Posted by Blake Terry on September 14, 2012 at 07:55:44 from (66.0.35.76):
In Reply to: Re: Farmall 100 fast hitch posted by Janicholson on September 13, 2012 at 19:49:11:
That helps a lot. I will double check to see if it bleeds down with weight on it at mid level and go from there. I know I can hook up to my disc and it will lift it about 4 inches off the ground is all, but it doesn't leak down after it gets it to that point. It will hold it there all day. If I can rule the leak out then I will dead head my pump and see what I'm building. Can you buy rebuild kits for these pumps? Its the small gear pump style. Thanks again
