Posted by Janicholson on September 13, 2012 at 19:49:11 from (96.24.99.126):
In Reply to: Farmall 100 fast hitch posted by Blake Terry on September 13, 2012 at 13:25:18:
If the hitch is raised to mid level and a weight is placed on it and the hitch stays where it is, the piston is not leaking. If it goes down, it probably is. If it stays put, the issue is probably the pump. flow rating the pump, or at least pressure checking to see if it puts out ~1200psi when dead headed, is also a pump check. Jim
