New water pump and belt
Posted by BigTone on September 15, 2012 at 13:42:13 from (70.192.13.142):
I bought a new aftermarket water pump and installed it without adjusting for the fan belt.
How do you adjust for the belt, I see a nut and screw?
To get the fan belt on, do you put it around the crank pulley then rotate it onto the water pump pulley?
