Re: 1967 international harverstor 504 not getting the gas
Posted by rustyfarmall on September 15, 2012 at 14:11:26 from (67.55.162.174):
In Reply to: 1967 international harverstor 504 not getting the gas posted by dpatnaude on September 15, 2012 at 12:48:14:
It'll run without the air filter, so that has nothing to do with it. However, I strongly advise against running it for very long.
It is either starving for fuel, or the ignition coil is weak, or it is way out of time. How long since you changed plugs, points, condensor and set the timing?
