Disconnect the gas line at the carb and see if there's a full stream of gas from the tank. Hold a clean container to catch the gas. If that looks ok remove the tube fitting where your gas line connects at the carb. Look for a screen that be full of crud. If your carburetor has main jet adjustment like the M's and H's has you need to open it. That will enrich your fuel mixture. If none of this helps your carburetor may need a good soaking in carb cleaner and all the jets blown out with air. Hal
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
