Re: Rear tire valve core
Posted by Nebraska Cowman on September 18, 2012 at 07:29:06 from (66.252.116.102):
In Reply to: Rear tire valve core posted by 2farmron on September 17, 2012 at 20:52:46:
third party image
Yes, Like Old says. there is a core assembly that comes out. There are two styles, one with external threads and one internal. You need to figure out which one you have.
This is the male type thread used for the last 50 years. You seldom see the female style any more (but yes I have an 806 with that style leaking now)
