Posted by Zachary Hoyt on September 19, 2012 at 17:46:38 from (184.12.67.118):
I posted a question a bit ago about what type of 3 point adapter arms I needed. I found this set on ebay and they seem to address the problem of not being able to lift high enough. I took them and got the upper holes drilled out to 7/8 which cost me $15 and the arms plus shipping were $120, so it was not as costly as I had thought it might become. There is about an inch or two of slop from side to side when the bush hog is lifted up, but that is similar to a 3 point hitch with a stabilizer bar. I got the lights hooked up and really like having the rear work light and the dash light. I got a 12v bulb for the dash light that came with the new temp gauge I put in it. Now that it has a working gauge I found that it warmed up to 160-170 and stayed there for the time I ran it. The PTO slipped under load a couple of times so I need to check the band adjustment, and the PTO seal leaks but that will be an easy fix. I still need to work on the grill and get the right hood put on. I am wondering how the choke rod was originally routed, the replacement one is very sloppy but I don't dare to move it in closer to a straight line because of the starter relay being right there. Any advice will be much appreciated. Zach
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
