Eric mowers are designed to run a minumum blade tips speed to get a proper cut. Running at half throttle isn't giving you the tip speed you need. That deck and any of the 3 point 540 rpm decks are desighed to run at 540 PTO speed. That means very close to max engine speed. Also make sure the deck is slightly nose down. If it's nose up you are cutting twice at both the highest blade in the front and again at the back end that is lower.
I run a Woods RM59 on my 8N. I can mow about 4 acres an hour in first and can mow in 2nd too. But the Ford is fast in first and with trees and shrubs 2nd is just too fast to be safe. As long as the bades are reasonably sharp I get a really nice cut too.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
