Re: Super M Motor vs. a 450 motor
Posted by Andrew Z on September 26, 2012 at 04:52:03 from (64.252.140.206):
In Reply to: Super M Motor vs. a 450 motor posted by Skip Nelson on September 26, 2012 at 04:12:06:
You can put the 4 1/8" "450" pistons in a C264 (Super M block) but there are other differences as well. The cam, carb, and head are all better versions then the Super M. Super M is around 48ish hp and a 450 is 58ish hp. If you were going to just use it then it would be ok, as a collector tractor id shy away. But im a purest.
Andrew
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
