Super M Motor vs. a 450 motor
Posted by Skip Nelson on September 26, 2012 at 04:12:06 from (64.12.116.73):
Ok all Letter series Doctors. I have an opportunity to purchase a Super M w/f with a 450 motor in it. Would you say I would be better off with a Super M or this changed out one. Will I notice a difference in the Hp or not. I am a Super M nut but was wondering if their are any real advantages of this swapped out Super. No other mods are on it. The cost is relatively the same for either tractor. Thanks for your Red opinions!!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
