Re: Super M Motor vs. a 450 motor
Posted by mkirsch on September 26, 2012 at 05:26:29 from (64.80.110.74):
In Reply to: Super M Motor vs. a 450 motor posted by Skip Nelson on September 26, 2012 at 04:12:06:
How do you mean "better off?"
If you want a running, useful tractor, this one's good, and the price is right, you're no better or worse off with this one.
If your goal is a "numbers matching" original, then you're better off with a "pure" Super M.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
