Re: Super M Motor vs. a 450 motor
Posted by DeltaRed on September 26, 2012 at 06:27:05 from (67.6.219.50):
In Reply to: Super M Motor vs. a 450 motor posted by Skip Nelson on September 26, 2012 at 04:12:06:
My SM was biult up to 450 specs. when I OHed it.It did give it quite a bit more power.If your a member of the 'Correct police',then you probably wont like it.Other than that,go for it,You will enjoy the extra power.BTW,a local fellow has a 248(M motor) in a 450.Makes a weak/sick 450!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
