Re: Super M Motor vs. a 450 motor
Posted by randy hall on September 26, 2012 at 08:32:08 from (216.255.38.205):
In Reply to: Re: Super M Motor vs. a 450 motor posted by D Slater on September 26, 2012 at 07:14:54:
Dave, i think you have the same serviceman's handbook that i do. did you ever notice that the 450 has .5 less horsepower and uses a little more gas and 3 less lbs. of compression with the replacement fire-crater pistons instead of the original flat pistons?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
