Re: Super M Motor vs. a 450 motor
Posted by D Slater on September 26, 2012 at 12:14:47 from (184.15.50.155):
In Reply to: Re: Super M Motor vs. a 450 motor posted by randy hall on September 26, 2012 at 08:32:08:
Randy don't have the same info you do. What I have shows both equiped with the recommended fire crater pistons should have the same cranking PSI.
But some other early info printed shows the 450 having a lower cranking pressure. Don't know if it was due to the different cams or not.
Course this is all just discussion now from years ago. In the real world now I have had a couple of M tractors with M blocks that would put it all over a lot of SM and 450 tractors.
Like autos that are supposed to be the same but some just run better than others.
Can't remember for sure without looking but think M&W claimed more power out of a early block with there parts than a 281 with there parts.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
