Re: Super M Motor vs. a 450 motor
Posted by Skip Nelson on September 26, 2012 at 09:27:09 from (205.188.117.74):
In Reply to: Super M Motor vs. a 450 motor posted by Skip Nelson on September 26, 2012 at 04:12:06:
Thanks for all the replies. I should have said I am not interested in the authenticity of this particular purchase but more interested in the HP difference (noticeable) between the two: Super M vs a 450 in the Super M chasis. From the last two replies it looks as if the Super M has more hp then the 450. I would venture to say that a Standard Super M would have it over the 450 swap?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
