SMD Thompson Live pump - leaking
Posted by Dan MD on September 26, 2012 at 18:01:44 from (184.158.79.230):
I had a bad leak between my pump body and the manifold underneath, caused by old flat o-rings. I installed new greased O-rings and it is substantially better, but still leaks maybe 3 drips a minute from between the pump housing and the manifold underneath. Are there any other tricks to seal this up? The manifold doesn't have the smoothest sealing surface finish I've seen.
Thanks,
Dan
