I would first remove the pump & check the oring grooves to be sure you hadn't missed any stubborn remnants of the old orings in the bottom of the grooves.
Take your "new" orings with you to a hydraulic parts & repair shop & see if they can provide you with slightly oversized ( thicker not larger diameter) vitron orings.
Check the flatness of both the pump boss & hydraulic line block with a straight edge. If they are warped take a flat mill b-tard file & GENTLY flatten the surface, the pump housing is aluminum so go easy, a little goes a long way. After removing 10 to 20 thousandths from each this will squeeze the orings a bit more & hopefully stop the slight leak.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
