Re: Farmall M wireing
Posted by The Red on September 27, 2012 at 13:44:47 from (69.246.205.0):
In Reply to: Farmall M wireing posted by BigTone on September 27, 2012 at 12:15:20:
Anthony if that is a Delco generator converted to 12 volts (I had several converted through the years) one post should have a letter stamping of A next to it in the housing and the other of F for field which is the ground side. Should be the same configuration from 6 to 12 volts. At least that is what I found on the 2 Hs and 2 Ms I converted.
