Farmall M wireing
Posted by BigTone on September 27, 2012 at 12:15:20 from (67.248.255.222):
Im re-wiring the tractor and as I look at farmallbobs diagrams it has three wires hooked to the fuse (regulator L to fuse, fuse to light switch, and ignition switch to fuse) but there is only 2 connectors, what am I missing? (im using a 2 wire key ignition if it matters, not the original push/pull switch).
My other question is, I have a 12 volt generator, are the A and F terminals on the gen. the same for 6 volt as they are for 12? (the top screw on the gen. has a black washer and the bottem screw has a red washer, ground and hot?)
thanks for the help guys, ~Anthony
