Re: 450 single spline/DUAL spline axles?? ARE THERE 2 KIN...
Posted by Mike1972chev on October 02, 2012 at 15:25:14 from (99.50.226.240):
In Reply to: Re: 450 single spline/DUAL spline axles?? ARE THERE 2 KIN... posted by mkirsch on October 02, 2012 at 13:31:21:
WTF?????????
They cut a hole in the axle housing and welded it back rather than buy a new axle?????
I guess this would be some kind of SERIOUSLY,cheap,quick,"farmer repair" procedure????
(You think they would have AT LEAST remove the innner "stub" from the Bull gear and axle housing and make some kind of jig to weld the two broken halves together EXTERNALLY on a bench????)
