As good as the above is, you neglected to mention the condenser (capacitor.) Points type systems will not generate a spark without a GOOD condenser
"New" does not mean "good" IE operational.
I always take the points temporarily "out of the problem" by bumping the engine until the points are open. With the switch on, check for battery voltage on the points side of the coil.
If you have that, pull the coil wire, and short the points side of the coil to ground several times, either at the coil, or right at the points, which will check the distributor primary wire. If you can generate a spark by doing so, clean up the points, check the gap and see what you have.
I ALWAYS keep old but "were running" condensers, and have seen new ones defective out of the box
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
