Re: Recommendation Hydraulic Valve
Posted by mkirsch on October 05, 2012 at 11:00:07 from (64.80.110.74):
In Reply to: Recommendation Hydraulic Valve posted by Sparky2 on October 05, 2012 at 07:31:02:
He already has the fast hitch.
Easy way to run the loader is to lock the fast hitch in position and use the existing valve to run the loader. That is what is normally done.
I do not know if a bypass block will work with the fast hitch valve in place. Normally it is used with a plain hydraulic manifold. Theoretically it should not be a problem, but you never know.
