Re: Recommendation Hydraulic Valve
Posted by Sparky2 on October 05, 2012 at 11:22:19 from (96.35.129.251):
In Reply to: Re: Recommendation Hydraulic Valve posted by mkirsch on October 05, 2012 at 11:00:07:
Easy way to run the loader is to lock the fast
hitch in position and use the existing valve to
run the loader.
Do you lock the fast hitch in place mechanically?
If so, I assume you disconnect the fast hitch
lines and reconnect/pipe to the loader. Is that
it? By the way, I do not need the control arms to
work on the side of the tractor, can they be used?
