Posted by John Fulton on October 05, 2012 at 11:57:10 from (67.142.174.20):
Am taking Janicolson"s advise on correcting front end wobble of an H Farmall regarding replacing bushings and sector gear on top bolster shaft. Standard 2 or 3 arm gear puller does not fit over the half moon shaped sector gear. Does anyone have experience in doing this? Is there another type gear puller that will work? This gear is swedged on really tight, and I cannot remove shaft for inspection without sector gear coming loose first.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
