Re: Pulling sector gear from bolster shaft...
Posted by Rod51M on October 05, 2012 at 17:41:40 from (71.254.223.168):
In Reply to: Pulling sector gear from bolster shaft... posted by John Fulton on October 05, 2012 at 11:57:10:
As a side note, my M has front end wobble too when in high gear on the highway. I think I traced it down to slack between the half gear and the tapered spline it mates to. It is down as far as it can go on the spline so I can't tighten it anymore. I got some thin brass shims about 1/8" to 1/4' wide and I am going to try placing them between the gear and spline to try and fill the gap/slack. Does anyone see anyway that this might damage anything that I am not thinking of?
