Re: O.A.L. of belly control rod for 49M.
Posted by BigTone on October 05, 2012 at 13:40:25 from (70.192.2.72):
In Reply to: O.A.L. of belly control rod for 49M. posted by Patrick HMD on October 05, 2012 at 09:17:45:
Please take into account these measurements are as close as I can get, after 63 years of use it is not as straight as brand new but his should get you close.
Total Length: 43"
From the control lever end: 1" until it bends 90 degrees and the cotter pin hole is 1/4" to the center of the whole. After it makes the bend the rod continues for 39" until it bends again to make the loop handle of the control rod. There is also a 1/4" long piece of rod (im imagining is 3/8") that is welded 4 1/8" down from the bend in the handle loop to the center of the piece of rod.
I hope this helps, and good luck! ~Anthony
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
