radiator placement
Posted by Rod51M on October 05, 2012 at 17:34:16 from (71.254.223.168):
I am putting the radiator back on my M after being re-cored ($$$ ouch!). There is a good bit of front and back play where the two bolts on the bottom of the radiator go through the frame. Any suggestions on where it should be placed? Where should the shroud be in relationship to the fan? Even?
This got me thinking about a gap that this tractor always had between the grill and the hood. The recessed area of the grill (where it meets and goes under the hood) always showed quite a bit and it seemed as if the two peices should be moved towards each other. Since the grill bolts to the radiator, can I close this gap by moving the radiator closer to the engine?
Thanks for you help.
