Re: radiator placement
Posted by D Slater on October 05, 2012 at 17:54:54 from (184.15.8.46):
In Reply to: radiator placement posted by Rod51M on October 05, 2012 at 17:34:16:
Place it so the hood fits the best you can get it and the steering shaft doesn't contact the radiator hole it passes through. Then make sure the fan clears the fan shrould to see if anymore adjustment is needed. May not get everything perfect at the finish. Some tractors sometimes need a shim under the mounting pad or pads to get the best fit.
