Posted by Janicholson on October 06, 2012 at 13:06:28 from (96.24.99.126):
In Reply to: 3588 torque ? posted by Greg Hammel on October 06, 2012 at 12:23:51:
If the tractor operates as follows, it has a front or direct TA clutch that is weak, or has a failed hydraulic piston seal, or seals in the supply pathways to the piston. When in direct, the tractor will operate pretty well normally in lower gears when lightly loaded, or coasting. When a load is applied (such as lowering a disk into soil, the tractor will go into the governor a little, then start to slow down to the speed of the TA reduction. if the TA is pulled back, the tractor will continue at that speed. If this is not the case, if the tractor continues to go slower, than TA back, then it likely has a weak master clutch. if not other issues. Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
