Another clutch problem
Posted by BigTone on October 06, 2012 at 15:49:56 from (70.192.15.200):
Went to adjust the clutch and the Nut wont move. Hit it with pb blaster for hours and nothing. I measured the free play from the transmission deck to the point that the pedal engages the bearing and its close to 2" of free play, the book says 1 1/8". The bearing is about a 1/4" away from the clutch fingers when the pedal is against the transmission deck and i was told it should be 1/8th.
Should I be looking for a new clutch rod? I might be able to get the nut loose with heat and a few days of pb blaster but im afraid the rod wont screw into the bracket. Any ideas? ~Thanks, Anthony
