Re: Another clutch problem
Posted by kevinj54 on October 07, 2012 at 12:31:52 from (50.36.187.64):
In Reply to: Another clutch problem posted by ridgelane on October 06, 2012 at 15:49:56:
In my ops book it is on PAGE 60.
"It is important that a clearance of 3/16" be maintained between the clutch release bearing and the clutch release levers"
"In order to maintain clearance the clutch pedal free play should be 1-1/8", measurement to be taken between the point of contact of the clutch pedal arm with the rear frame cover when clutch is fully engaged"
"the correct free movement can be maintained by adjusting the length of the clutch operating rod between the clutch pedal and the release shaft lever"
Hope this helps.
