Re: Farmall M Hydraulic Pump out put shaft seal
Posted by charlieu on October 08, 2012 at 05:18:52 from (209.131.224.196):
In Reply to: Farmall M Hydraulic Pump out put shaft seal posted by Peter Hendrickson on October 07, 2012 at 17:12:45:
third party image
third party image
Here is a picture of a tool made for removing the drive nut. With the tractor in high gear and the brakes set you can unscrew the drive nut from the tramission counter shaft. With the square key of the tool in the slot of the nut, as you put a little pull on the tool take a hammer and tap on the nut.
I also have a tool made for removing the nut from the pump, but I can't find the picture. I took an old inpact socket that I welded a piece of key stock to that fits the nut and with the air impact wrench I have been able to remove the nut from the pump without any disassembly of the pump assembly.
Hope this helps, charlie
Today's Featured Article - Buying your first tractor: The People You Buy From - by Chris Pratt. If you are a first-time buyer, chances are that you are likely to take the word of the seller on things. This is where the problems start... You have reviewed your implement needs and determined the size of machine that will fit the bill and even made a list of the most desirable models. You checked on the availability of a 3-point hitch for the machines on the list and advertised in your local classified paper with so ... [Read Article]
