Farmall M Hydraulic Pump out put shaft seal
Posted by Peter Hendrickson on October 07, 2012 at 17:12:45 from (97.83.157.85):
anyone tell me how to get the coupler off that hooks to the hydraulic pump in the belly of the M so that I can get the seal out of the housing that is leaking? tried a small gear puller and the thing wont budge.
Thanks in Advance
Today's Featured Article - Buying your first tractor: The People You Buy From - by Chris Pratt. If you are a first-time buyer, chances are that you are likely to take the word of the seller on things. This is where the problems start... You have reviewed your implement needs and determined the size of machine that will fit the bill and even made a list of the most desirable models. You checked on the availability of a 3-point hitch for the machines on the list and advertised in your local classified paper with so ... [Read Article]
