Putting a 6bt 12 valve cummins in IH350?
Posted by Jonnymac348 on October 11, 2012 at 04:29:15 from (68.9.29.13):
I was wondering to pick anyones brain I am looking into putting a 6bt 12 valve cummins into a International 350 tractor. I know you can buy or make the adapter plate and have to change the fly wheel. Was wondering if anyone knew what would need to happen with the front end mounting to the cummins. Assuming you would have to make new mounts. and was wondering if the front end would mount back again on the stock spot behind the oil pan where the pivot ball is with no modification or what would need to be done. what kinda flywheel should i use or buy.
Any and all help would be much appreciated.
Jon
