Re: ballasted weight?
Posted by SDE on October 11, 2012 at 17:13:32 from (174.124.53.135):
In Reply to: Re: ballasted weight? posted by Dave_Id on October 11, 2012 at 15:58:55:
Water was 8.4 per gallon, times 55 is 462lbs. About 500 each is close.
SDE
