Re: ballasted weight?
Posted by John G. Hasler on October 11, 2012 at 19:03:47 from (174.124.54.72):
In Reply to: Re: ballasted weight? posted by SDE on October 11, 2012 at 17:13:32:
11.5lb/gal for calcium chloride solution, so about 630lb at 55 gal per tire.
