Re: Re: 1946 'M' Farmall
Posted by Haas on October 18, 2000 at 05:43:31 from (129.37.117.225):
In Reply to: Re: 1946 'M' Farmall posted by Dale13 on October 18, 2000 at 02:42:12:
Best to drain the belt pulley too. If there is water in the trans, there will be water in the pulley case too. You have to take the bolts out that hold the pulley assembly in the housing and slide it out to drain. Then fill it up with about a pint through the plug in the top of the pulley housing.
Post A Followup
: Re: Re: Re: 1946 'M' Farmall
