Re: broken starter nose cone
Posted by D Slater on October 15, 2012 at 07:22:34 from (184.15.8.46):
In Reply to: broken starter nose cone posted by tom dowling on October 14, 2012 at 17:59:22:
Can't be a very big piece if its between the flywheel and the steel plate on the rear of the engine. Trouble is even a small piece could wedge in the space. Right between the engine and flywheel the only things to catch on is the bolt heads mounting the steel plate to the engine and the rear main seal housings. After removing the bottom plate. Think I would try to see if a stiff wire or a long thin flat piece of metal would go up and dislodge the piece before spliting. Also a couple of places in the clutch housing on each side of the flywheel for a piece to rest on.
