Posted by pete 23 on October 15, 2012 at 10:23:14 from (74.32.238.2):
In Reply to: nosie706..263 posted by morris roessler on October 14, 2012 at 22:46:47:
Morrie, take the oil filter off and look for bearing material. If you see any you know you are done right now. If not, well, maybe it is end play on thrust bearing but if it is it will go away when you push clutch pedal. If mains are actually loose enough to pound you will be able to move the crank up and down either under front pulley or under flywheel.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
