nosie 706..263
Posted by morris roessler on October 15, 2012 at 22:19:40 from (69.163.6.36):
well tomorow i will check the oil filter for bearing material and drop the pan and see if anything is lose.... if not... it is going on the plow...if anybody is interested i will let you know what happened.
