Re: nosie 706..263
Posted by Janicholson on October 16, 2012 at 07:07:12 from (199.17.55.139):
In Reply to: nosie 706..263 posted by morris roessler on October 15, 2012 at 22:19:40:
If someone else built the engine, get them involved. If you were the 'buck stops here' guy, you really need to assure yourself it is worth the risk. (flywheel bolts??? make rod sounds) Jim
