Re: splitting revisited
Posted by hayfarmer on October 21, 2012 at 12:14:43 from (71.80.194.62):
In Reply to: splitting revisited posted by pete_5959 on October 21, 2012 at 10:52:03:
What are you going to work on? Most common split is at bell housing. I have s set of split stands I made to support the engine, front end then rolled the back part away on a support with wheels. I have also done it by supporting the rear with a heavy floor jack, chained to tractor rear end. Helps if you have cement floor for that.
