Re: splitting revisited
Posted by John G. Hasler on October 21, 2012 at 13:08:04 from (174.124.22.175):
In Reply to: Re: splitting revisited posted by hayfarmer on October 21, 2012 at 12:14:43:
> Helps if you have cement floor for that.
You can say that again! The first time I split my 544 I did it on gravel. I used lots of timbers and come-alongs to skid it on the timbers while maintaining alignment, but it was still a pain. Then there was getting it back together...
The second time I used a concrete floor. A cracked one. I"m not sure it was better than the gravel.
Oh, and you really want to make a set of alignment dowels. Just grind the heads off some appropriately-sized bolts.
