Re: Re: Re: Re: Re: Throttle/Governor on C
Posted by Chris on October 19, 2000 at 18:37:00 from (64.24.62.58):
In Reply to: Re: Re: Re: Re: Throttle/Governor on C posted by FC on October 19, 2000 at 15:38:19:
I think it could behave this way. An engine at half thottle isn't exerting as much force on the flyweights as it would at full thottle which means the spring doesn't have to work as hard to hold it open. If you think it might be out of adjustment, a basic place to start is, with the engine off and throttle lever at max position, to adjust the gov-carb linkage so the thottle is wide open--no RPMs means no centrifugal force means no resistance to spring whichs means the spring will yank the throttle wide open. Just a question--are you not able to physically push the lever to the max position? If so, have you verified that the RPMs at max throttle advance are too low? Good luck, Chris
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
