Hyd. Control valve leaking on my 400
Posted by SDE on October 23, 2012 at 15:31:00 from (174.124.32.149):
When the ram gets to the end of its stroke, fluid comes out of the top portion of the control valve. I think it is exiting the o-ring on the lever shaft.(#29 and #18 and #19) Which means I will need to pull the control valves off the tractor to replace them. Is the fluid bypassing a different seal and I should replace that one as well? Is something worn out in the control valve that lets the fluid go somewhere it should not be?
Thank you
Steve
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
