Re: Hyd. Control valve leaking on my 400
Posted by pete 23 on October 24, 2012 at 10:35:46 from (74.32.238.2):
In Reply to: Hyd. Control valve leaking on my 400 posted by SDE on October 23, 2012 at 15:31:00:
I assume you are working on a IH Farmall 400. If so, yes you have to take the valve off as the shafts go out both sides. Held together with a roll pin. That little square block you will find inside is just to keep the roll pin from falling down into the valve if it comes out, or when you drop it while putting it back together. No kit , all individual parts all the years I worked for IH. Lots of o-rings between valves, under cap, and there are very tiny o-rings on the unlatching piston. That piston can cause excessive oil to build in end of valve but I still doubt it would make it leak, but stranger things have happened. Maybe internal parts have come loose where unlatching piston goes.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
