Re: Wiring Diagram for 400 farmall 12v alt conversion
Posted by Roy J. Mantonya on October 23, 2012 at 17:08:39 from (207.155.75.66):
In Reply to: Re: Wiring Diagram for 400 farmall 12v alt conversion posted by Janicholson on October 22, 2012 at 20:17:38:
no prolonged cranking when it works it'll fire right up. i think I will just go end to end with new wireing and see what goes then. How can I be sure about the rebuild job? you mentioned bushings last awhile, if it's a rebuild it ought to all be new right?
