Re: Cranked her up All four clyinders even H farmall
Posted by The Red on October 20, 2000 at 03:11:36 from (12.75.197.49):
In Reply to: Cranked her up All four clyinders even H farmall posted by Bob R on October 19, 2000 at 16:21:43:
Congratulations Bob. That is a good feeling hearing an old piece of iron coming back to life. If you are not using the belly pump, I would recommend you remove that short drive countershaft that runs the liftall. The seal in the liftall and the main transmission driveshaft seals are fairly easy to replace. Don't be surprised if the countershaft transmission seal is leaking also.
Post A Followup
: Re: Re: Cranked her up All four clyinders even H farmall
